Which sub is best?
Discussion in 'Subwoofers' started by Northmoorblue, May 18, 2004.
  1. Northmoorblue
    Northmoorblue
    May 18, 2004
    49
    I am just starting to get into home cinema, and am looking for some advice on the following points.
    I have recently bought the KEF KHT5005 speaker package that comes with the PSW 2500 sub. Will this be designed to work with the speakers more effectively than a different sub.
    I already have a REL strata 3. Would it be better to stick with this, as it is a better sub? I bought the package because I liked the speakers performance & looks (experienced at various shows) and thought the whole thing would work better together.
    Will I infact notice a difference at all?
    Does is also depend on what other equipment I have?
    I don't need 2 subs, so I need to decide which one to sell?
  2. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    If you have both subs, test them - set each one up in your room and demo with suitable DVD and music material. Let your ears/bowels decide. :D
  3. Ian J
    Ian J
    Aug 6, 2001
    25,639
    +4,906
    There is no tonal matching of a subwoofer to speakers so in theory any decent subwoofer will go with any main speakers equally well. The better the subwoofer, the better the overall sound will be.
  4. Northmoorblue
    Northmoorblue
    May 18, 2004
    49
    Thanks for your opinions. Its all new to me so I appreciate any advice from seasoned professionals.
    Northmoorblue
