Which Sub for upto £300
Discussion in 'Subwoofers' started by ALIEN1X, Jan 15, 2008.
  1. ALIEN1X
    ALIEN1X
    Jan 7, 2006
    487
    +19
    I have max £300 to spend for a Sub- mainly watching movies , and I have been flicking thru 'What HiFi Sound and Vission'.
    For the price range and top reviews I have a choice of the following:
    MJ Acoustics Pro50 MK2
    Mordaunt MS309i
    Velodyne CHT8R
    Wharfdale SW150 or SW250
    So anyone tested these?
    Regards
    Alien1x
  2. Andori
    Andori
    Dec 7, 2006
    1,336
    63
    Lincoln
    +220
    What about the BK XLS200? Under £300 and a popular choice on here.
  3. nigel77
    nigel77
    Jan 19, 2007
    727
    Devon
    +31
    I'd agree with Andori.
    It's a toss up between the BK electronics XLS200 @ £289 or MS 309i @ around £220. The BK and MS are very closely matched in terms of performance with the BK being more compact and having nicer build qualitiy.
    Nigel
  4. ALIEN1X
    ALIEN1X
    Jan 7, 2006
    487
    +19
    Thats strange, its not mentioned or reviewed in Home Cinama Sound and Vission?
    Regards
    Alien1x
  5. Scott_Mac
    Scott_Mac
    Jul 4, 2005
    6,110
    2
    2
    Bromsgrove
    +628
    BK are the manufacturer, and make (or made) subs for a lot of the major manufacturers.... i understand REL and MJ Acoustics to name a couple of good names.
    I agree with Nigel though, for the money it's the toss up between those 2, both superior to the units you mentioned
  6. nigel77
    nigel77
    Jan 19, 2007
    727
    Devon
    +31
    BK electronics sell direct to the public and as such are able to offer you much better price v performance. The XLS200 is very similar to MJ acoustics REF200 which retails at £650, which would you buy:D.
    Take a look here: http://www.bkelec.com/HiFi/Sub_Woofers/XLS200-DFandFF.htm
    Just click on the version your interested in down firing or forward firing.
    The bulid qualitiy is second to none, cabinets have a choice of real wood veneer at no extra cost and you get a 2 year warranty.
    Regards
    Nigel
  7. madwelsh
    madwelsh
    just to up the stakes a lil, as I myself was mulling over the 309, you can find them at a shade under £175, google is thy friend :)
  8. yetanotherbob
    yetanotherbob
    Mar 22, 2007
    637
    28
    London
    +55
    Another thumbs up for the BK XLS200 it's a lovely little box.
    There is actually a review of it in the February issue of Home Cinema Choice (p.98)
    They sum it up by saying:
    "This BK is bogglingly potent for it's size and absurdly good value for money. Just think you could have three or four of these for the cost of the bigger ones in this group"
    But then we already knew that on this forum :D
    BTW, It was the only piece of AV equipment I've ever bought blind and was solely on forum recommendations and it didn't disappoint.
    Bob
  9. Special agent
    Special agent
    Oct 3, 2005
    114
    Derby
    Go for the BK XLS200, you won't be disappointed, I was run over by a tank in Saving private Ryan. !
  10. Ian J
    Ian J
    Aug 6, 2001
    25,639
    +4,906
    BK may have manufactured subs on behalf of REL at one time but certainly not in the last 10 years
  11. Scott_Mac
    Scott_Mac
    Jul 4, 2005
    6,110
    2
    2
    Bromsgrove
    +628
    I always wondered when that was... thanks Ian :)
  12. MickyGee
    MickyGee
    Jan 6, 2005
    294
    Preston
    For under £300 only one choice - BK XLS 200 mk2
  13. ALIEN1X
    ALIEN1X
    Jan 7, 2006
    487
    +19
    Will the BK give a thumping/ground shaking base?
    Will it cut off at low signal levels /auto shut off during quiet movie tracks?
    Can and how can I connect them to Active speakers that have a sub output known as volume adjustable output via strereo mini jack output? .i.e Like yamaha YST M100?
    Regards
    Alien1x
  14. Gavin C1
    Gavin C1
    Jul 25, 2006
    393
    28
    Houghton-le-Spring
    +28
    I second this. I bought this sub going off what people on this forum recommended and it arrived a couple of days ago. I must say, I'm loving it :thumbsup:
    I got the downward facing one and it looks really nice, and sounds even better!
    XLS200 is the way forward :cool:
  15. ALIEN1X
    ALIEN1X
    Jan 7, 2006
    487
    +19
    :confused:Hi, please kindly see thread no.13
    Also, if the both 309i and xls200 are similar in quality why not go for 309i as its cheaper?
    Alien1x
