which sub £400 av amp to get...
Discussion in 'AV Receivers & Amplifiers' started by rozzar, Mar 22, 2006.
  1. rozzar
    rozzar
    Sep 29, 2002
    1,056
    41
    Braintree
    +23
    all i need is:
    video up conversion (i.e. composite to s-vid, s-vid to component etc)
    7.1 amplification
    full preouts
    on screen (on tv) display
    Is Yamaha '657 the only real answer?
    I liked the sound of my old HK with Logic 7 but thats gone now and the AVR635 is pricey at a grand....
    What about the Pioneers- the model before the AX2, what was that called and did that have video up?
    Thanks guys :)
    Rory :clap:
  2. Poindexter
    Poindexter
    No, but it's a very good one. Had mine for nearly a week now and absolutely thrilled to bits! :thumbsup:
    Dex
  3. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Maratnz 5600;)
  4. amills2005smart
    amills2005smart
    Nov 8, 2005
    255
    Leeds
    +34
    You can get the Yamaha 757 which is the model up so should have all the features you need for less than £400 mate, try digital direct or richer sounds website. (im also consdiring one of these!)
  5. limegreenzx
    limegreenzx
    Feb 9, 2006
    2,018
    +337
  6. rozzar
    rozzar
    Sep 29, 2002
    1,056
    41
    Braintree
    +23
    that sounds cool guys, thanks....2 problems
    1 is that it only has 4 visual inputs- i need 5:
    xbox
    divx
    dvd
    dvdr
    vcr
    2 is that its being replaced very shortly; or so avland told me!
  7. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Sell the VCR, buy a DVD with divx...:devil:
  8. rozzar
    rozzar
    Sep 29, 2002
    1,056
    41
    Braintree
    +23
    i have a dvd with divx- its called a Pioneer DV585 and it does a pretty poor job of playing dvds.
    I have a dvd player- a Pioneer DV747a that does a nice job of playing dvds :)
    I have a dvd recorder- a JVC DRM10 that doesn't play divx, let alone VHS ;) and is a pretty poor dvd player too!
    i did have a look around for divx playing dvd recorders but couldn't find any (i'm not buying a samsung!)
  9. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    :confused: :confused:
  10. limegreenzx
    limegreenzx
    Feb 9, 2006
    2,018
    +337
    The DSP-AX757SE does have more than 4 switched video inputs. There is an Aux video input at the front of the amp. However, you can also connect more than 4 video inputs at the back, the only thing you have to do is be a little bit creative with the I/O assignments.
    The DSP-AX757SE may be due for replacement, probably around June time, but that doesn't make it a bad buy. I would say it's the opposite - the DSP-AX757SE is being heavily discounted the replacement will sell close to RRP when released. There was very little difference between the DSP-AX750 and the DSP-AX757, I expect the same with the DSP-AX759 and the DSP-AX757.
    Finally if you look at AVLAND they have the RX-V559 on pre-order for £350 the same price as the DSP-AX757. You can get a RX-V557 for under £240.
