which speakers
Discussion in 'Home Cinema Speakers' started by joel112, Jun 22, 2003.
  1. joel112
    joel112
    i am looking for a decent set of speakers.... but have a budget of 500,
    i was looking at the mordunt short speaker pack
    http://www.hifibitz.co.uk/Warehouse/details.asp?ProductID=MORPREMIERECH
    or the missions here, but they dont have a sub, wich i would prefer.
    http://www.hifibitz.co.uk/Warehouse/details.asp?ProductID=MISCINEMA74BEBK
    which should i go for, and are there any other packs i should consider?
    not sure on what amp to use with them yet, but it couls possibly be the
    Sherwood RD8108 or
    Yamaha DSPAX630
  2. Hawklord
    Hawklord
    Feb 15, 2003
    3,518
    3
    Aldershot, Hampshire
    +286
    How about for £257:-
    http://www.qed-uk.com/?i=0__4li3i3-0w&vp=6&bg=216&bp=cin71b&bi=0
    and that'd leave you enough money to buy a subwoofer like the vx-10 in the power buy section (around £200). Slightly more than your budget but worth the little extra for a decent subwoofer. I've had the M71 package in the past - i still use most of it for my rear sound stage . It is a really good package imo and will perform admirably for both films and music. You'll be hard pressed to find anything better for the money , but, why not go and have a listen at your local dealer and make your own mind up. I used the Yamy Ax620 at the time so I'd imagine the similar ax630 would complement the speakers well.
  3. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
    Hifi Choice reviewed the Mordaunt Short package here and rather liked it, awarding it four stars.
