which speakers
Discussion in 'Home Cinema Speakers' started by waylander, Mar 2, 2002.
  1. waylander
    waylander
    Jan 31, 2002
    I have at the moment a yamaha 620 amp and have about £800 to spend on a speaker package, I am looking at the kef eggs but can anybody suggest any other speaker packages or are they the best i can get for that price
  2. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    Just a usual Mission-bias suggestion from myself, but what about the Mission Cinema 7 pack from Richer Sounds for £400 (usually £800 itself), which will leave you with the proper budget for a sub. Good subs can't be bought for less than £400, which is sadly why I don't have one... :(
  3. Guest
    The mission m72 cinema pack?
    Which I got for 283 from QED (hey! that rhymes!)
    Or the mission 7 cinema pack with a subwoofer?
    -TF
  4. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    The Mission Cinema 7 package consisting of the 773e mains, 77c1 centre and 77ds rears. Plus a seperate sub.
