Which Speakers?
Discussion in 'Home Cinema Speakers' started by adamhamilton, Feb 20, 2001.
  1. adamhamilton
    adamhamilton
    I'm planning to buy some home-theatre speakers. At the moment I'm looking at the KEF Q35.2 front, Q95C centre, Q15.2 rear.
    How do these speakers compare to say the Tannoy MX series?
    Also, what sub should I get?
    Thanks,
  2. dood
    dood
    Aug 4, 2000
    947
    28
    Hobart
    +38
    if you go with kefs be sure to get the 95C.2 which has replaced the 95C and would better match the rest. What's your budget for the sub - the Yamaha SW320 would slot in quite nicely with the kefs.
  3. Big Jim
    Big Jim
  4. adamhamilton
    adamhamilton
    I have a budget of around £300 - £400 for a sub.
    I did actually mean the Q95C.2
