which speakers
Discussion in 'Arcam Owners' Forum' started by fatboyslim, Nov 7, 2004.
Tags:
  1. fatboyslim
    fatboyslim
    Hi I am buying a diva 300 and dv79 does anyone have any suggestions of which main and surround speakers go well with the system?
  2. johndon
    johndon
    Feb 3, 2002
    1,986
    63
    +122
    I've got a AVR300 & DV79 and I use Anthony Gallo Micros for the 3 front and two rear speakers. If you're looking for small speakers then I'd definately recommend them.
    HTH
    John
  3. fatboyslim
    fatboyslim
    cheers! how much they cost??
  4. Hifi addict
    Hifi addict
    the best question would be, what is you budget ..... then start selecting and listening
  5. johndon
    johndon
    Feb 3, 2002
    1,986
    63
    +122
    Depends on the finish but, if I remember correctly, they are £250 a pair for the solid colours and £350 a pair for the metallic finishes.
    John
  6. pringtef
    pringtef
    Sep 30, 2003
    1,072
    Amsterdam
    +70
    BIG fan of B & W kit with Arcam kit.
    Really like listening to CDs as well as watching movies, so got myself a pair of second hand CDM-9NTs, which cost me just under a grand. Stunning.
    Rear speakers, for around £400 you can get a second hand set of CDM1SE's which will more than do the job.
    I ended up just switching my CDM-7NTs which previously had been doing front speaker duties, and moved them to run as rear speakers, and it sounds awesome with 5.1 stuff, audio DVDs especially.
