Which speakers with my Arcam combo?
Discussion in 'Home Cinema Speakers' started by nashb, Aug 27, 2006.
Tags:
  1. nashb
    nashb
    Dec 15, 2004
    270
    16
    Nottingham
    Hie its me again. :cool:
    I am about to purchase the Arcam AV8/P1000 combo and wanted advice on front three speakers and a sub. :D
    I am going to use M&K s55 tripoles for the rears.
    My situation/criteria:
    HT/Music 70/30
    Music taste Soul, RnB
    Room size 20x12 feet
    Fronts must be floorstanders (aesthetics)
    Budget £2000ish.
    My hotlist of speakers:
    PMC
    Polk
    Dali
    Spendor
    Totem.
    Thanks in advance. :thumbsup:
  2. proux
    proux
    Apr 14, 2006
    1,067
    48
    London
    +57
    You may get more input in the arcam forum. PMC seem very popular.
  3. nashb
    nashb
    Dec 15, 2004
    270
    16
    Nottingham
    Thanks,
    Demoed the OB1s and FB1+s but not sure. :confused:
  4. Freshfighter
    Freshfighter
    Monitor Audio is an awesome match with Arcam. The new Gold series looks also stunning...
  5. nashb
    nashb
    Dec 15, 2004
    270
    16
    Nottingham
    Yes, but does it SOUND stunning! :rotfl:
  6. SKA.face
    SKA.face
    Out of the Speakers you mention I would take the Totems everytime,but I'm not sure how they would go with Arcam,but I think the Forrest will match well,be prepared for big grins:D
  7. nashb
    nashb
    Dec 15, 2004
    270
    16
    Nottingham
    Yes Ive heard they are good but not easy too demo.
  8. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,576
    Edinburgh
    +1,269
    Did you not like the PMCs?
  9. nashb
    nashb
    Dec 15, 2004
    270
    16
    Nottingham
    Wasnt sure about them
    Seemed a little flat/neutral?
    Because I listen to RnB/Soul I suppose I wanted some more sparkle.
    Whats your views?
  10. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,576
    Edinburgh
    +1,269
    That is the way they have been designed. Being a manufacturer of professional studio monitors, those very characteristics are what is desired. I understand that many people would not like it, particularly after so many years of listening to non-neutral/coloured speakers.
    My views are very favourable towards them, I like their honesty and no nonsense approach to reproducing the source accurately. If you are looking for more sparkle then the Monitor Audio GS series might suit you better.
  11. Bee-Man
    Bee-Man
    Jul 21, 2006
    94
    +5
    Chario Pegasus....give them a listen. Superb.....:thumbsup:
  12. nashb
    nashb
    Dec 15, 2004
    270
    16
    Nottingham
    Chario Pegasus :confused:
  13. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    A vote for the PMC's and Totems, the Totems would be an easier drive for the Arcam amps and I've yet to hear a bad Totem speaker, the PMC range are bit on the power hungry side. Crusty is spot on with his description. If the electronics behind the amps are flat and lifeless then that's what you'll hear.
  14. nashb
    nashb
    Dec 15, 2004
    270
    16
    Nottingham
    Knightshade: Have u any experience of Totem?
  15. Freshfighter
    Freshfighter
    Don't count the Monitor Audio's out. I actually recently upgraded to a pair of MA GR 20s (old series). I also demoed the GS series but there is not much difference in sound - more a cosmetical upgrade.
    But really, if you like dynamic sound - the arcam- MA cobo is really good. I would even suggest to go for the GS or GR 60s. They have an incredibly fast and thight bass. The old GR series can currently be found at bargain prcies. Bought my GR20s at about 1/3rd of the original price...
  16. nashb
    nashb
    Dec 15, 2004
    270
    16
    Nottingham
    Thanks ff, Ive heard alot of people recommend the MAs.
    Must demo! :(
  17. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    Apart from listening to them? No.....
    Not many speakers deliver what they can for the money. Their ease to drive should be a bonus for you. The Arcam amps that i've heard tend to loose their grip with difficult loads hence PMC don't sound great.
    I could recommend the Revel F32's. These truelly are a stunningly good speaker, bland as hell to look at but the performance far surpasses anything mentioned. However stick them on the end of some 100w into 8ohm amps and they'll be the worst thing you'll hear all day.
    Trick is to get the balance right. No sense spending a fortune on the speakers when the amps won't drive them. The recomendation for the MA gold series is good. They'll brighten up the somewhat laid back Arcam sound. However forget the GR 60's unless you spend more on the amps.
    Bottom line is take the time to demo. Loads of different opinions and loads of different ears. What's good for one isn't necessarily good for you. Take the time and get the right mix. Bigger isn't always better.
    I know of a few totem dealers around the country. Where are you?
    You may also want to give Focal JMLab a look another quite 'forward' speaker.
  18. nashb
    nashb
    Dec 15, 2004
    270
    16
    Nottingham
    Thanks for that.
    Im in crime-infested Nottingham. :D
