Which speakers to buy?
Discussion in 'Home Cinema Speakers' started by nickjm, Jul 22, 2005.
  1. nickjm
    nickjm
    Hi all,
    I'm wondering which speakers to buy for under £200. I have a yamaha AV receiver which allows me to do 6.1
    I was looking at the yammy NSP 106 speaker package, but I was wondering if anyone else has any thoughts about what I could better spend my money on, 6.1 is not essential, 5.1 would do.
    Many thanks
    Nick
  2. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    Go for 5.0 at this stage.
    Get 4 x bookshelf speakers eg. Mission or Kef or MA Bronze, etc. Plus a matching centre. Then save up a bit and get a better midrange sub later.
    A 5.1 setup for £200 will have a crap sub and poor speakers, usually sounding flat and harsh.
  3. nickjm
    nickjm
    Thanks for the reply, I waasn't sure whether £200 would cut it really, I shall take your advice
  4. scrowe
    scrowe
    Jan 8, 2005
    1,027
    116
    Brighton
    +554
    I'd check out the Canton CD1 set available in this forums powerbuy
