Which speakers should I get?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by gan*, Oct 18, 2003.
  1. gan*
    gan*
    Oct 18, 2003
    77
    I am looking to buy a NAD C521BBE, but I am confused about what speakers to put with it. I went to two Richer sounds stores, and they wanted me to get an eltax Liberty 5+ or a gale 3030.
    They said that they didnt have any connected up, but if I didnt like it once I bought it, I could exchange it for another. Bit confused as to what speakers to get though!! I was looking towards mission, but Richer said that they are not good at low volumes.
    I listen to mainly RnB and Rock.
    Any help would be great.....Thanks
  2. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,718
    71
    Land of the Living, Essex
    +34
    How about some Ruark Epilogue II's they are lovely, but I'm not to sure of your budget
  3. gan*
    gan*
    Oct 18, 2003
    77
    Oh sorry my budget is about £150, but could stretch to £200, if it would make a lot of difference.
  4. texasboy
    texasboy
    Sep 16, 2002
    390
    +15
    One of the best pairs of speakers available upto to £200.00 are the Monitor Audio Bronze 2 which are funnily enough £200.00
    Really good
  5. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,190
    Weardale
    +57
    yeah, Richer will always try and sell Eltax or gale speakers to you...saying that I've got Eltax...
  6. YS-YS
    YS-YS
    yeah the Monitor Audio B2's are the best in that price range, and they are not £200. try £199.95 that 5p makes all the difference.
    make sure when you buy them you get a couple of metres of silver aniversary in with the deal, else you start having to spend more money.
  7. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
    'If you don't like it when you get home...' doesn't wash with me as while you may not dislike what you hear, you sure don't know what you might be missing. Does Richer Sounds let you demo?
  8. Roam
    Roam
    gan*:
    You need to let us know what amp you are or will be using so you can then match your speakers accordingly.
