which speakers for sony 1080?
Discussion in 'Home Cinema Speakers' started by F1F3R, Mar 5, 2003.
  1. F1F3R
    F1F3R
    Dec 11, 2002
    68
    fife scotland
    i'm about too replace my sony davs 400 for a sony 1080amp
    which speakers would be best suited to this amp ?
    i currently have old B&W 601 (8 ohms) on spiked stands which sound ok .
    if they are suitable i would keep them and just get center , rears, and sub .
    my room is approx 14 x 12 feet . and i mainly watch dvds.
    i like the look off the B&W ... VM1 speakers and was considering them for the center and rears.
    are they ok too use with this amp and would they sound ok ?
    any help would be much appreciated.
    setup can be viewed at
    http://www.ascott1.pwp.blueyonder.co.uk/menu.htm
    then click home cinema.
  2. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    How about matching your existing 601s with an LCR60 for front (or a S/H LCR6) with 600s at the back?
  3. F1F3R
    F1F3R
    Dec 11, 2002
    68
    fife scotland
    ok thnx i'll look at these speakers.
  4. EvilMudge
    EvilMudge
    Have to agree with Vikki/Steff, even newer DM series speakers will be a closer match to your old 601s than the VM1s.
  5. F1F3R
    F1F3R
    Dec 11, 2002
    68
    fife scotland
    just had a look at these speakers , (b&w lcr range)
    looks ok but i would prefer silver or black , i think they only come with the wood effect case.
    so maybe still go for the VM1's .
    i know they are probably entry level speakers but does any1 know if they sound ok ?
    i havent seen any reviews on them . good or bad .
  6. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    The VM1s won a what hifi shoot out with other similar sized speakers. They beat the kef eggs etc...
    I know that What HiFi group tests don't always meet with the approval of a lot of people on this forum, but I am just reporting what happened in the test. If you don't like the result moan at What Hifi not me :devil:
    Steff
    (who loves b&w speakers so is slightly biased in these matters)
    Edit: I have to say though that unless you have money to throw away I would go for the better sounding centre which is the LCR60 because wouldn't you be thinking I wonder how good it would be with....
    The centre really is quite fundametal to 5.1 (yes I know it's 5 dot 1 and all six channels are important, but some are *more* important then others).
    :suicide: maybe that is why i'm so broke :suicide:
  7. Nobber22
    Nobber22
    Jun 6, 2002
    2,977
    Berkshire
    +109
    LCR60 definately comes in a black finish......check out www.bwspeakers.com and go to their products section/600 series/photo gallery/see the first pic ;)
  8. F1F3R
    F1F3R
    Dec 11, 2002
    68
    fife scotland
    thnx . ;)
