nwgarratt
- Joined
- May 5, 2002
- Messages
- 29,433
- Reaction score
- 3,612
- Points
- 4,249
- Age
- 49
I am about to setup an old Sony DB930 100W amp and B&W 602/601 speakers (probably just use the 601's). It will be used mainly for music. I have some old wire which was taken off the amp but I need longer wire now. I have no idea what spec the wire is so need something from ebay that will do. I see there are different gauges which makes it more confusing. The amp is set on 4 ohms but thinking of switching it 8 ohms as that is the nominal impedance.
I think the furthest speaker will be about 13m away and the other will be about 10m.
This ok?
This ok?
30m Transparent Auline® 2x 3.3mm2 Clear Speaker Cable Wire 105 Strand 12AWG | eBay
Auline Speaker Cable. Length 30m. 2 x 105 strand / 2 x 3.3mm2.
www.ebay.co.uk
-- As an eBay Associate, AVForums earns from qualifying purchases --
