Which soundcars are u guys using?
Discussion in 'Computer Components' started by petrolhead, Mar 2, 2003.
  1. petrolhead
    petrolhead
    Mar 29, 2002
    4,490
    71
    Newcastle
    +82
    What soundcard do you use in your HTPC?
    Just trying to get some ideas
  2. nutcase_1uk
    nutcase_1uk
    Apr 15, 2002
    479
    Essex, unfortunately
    +3
    Currently an M-Audio Delta 410, but I got a M-Audio Revolution a couple of weeks ago to see if that was ny better. Still trialling it :)
  3. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,357
    63
    East Yorkshire, England
    +171
    Hello Petrolhead,
    The M-Audio Dio, Delta 410, Audiophile or maybe the new revolution should be your choice.
    If you want more high end, the RME are superb at £160-£210, depending on model.
    The choice depends on the quality of the rest of your AV gear.
    Mark.
  4. petrolhead
    petrolhead
    Mar 29, 2002
    4,490
    71
    Newcastle
    +82
    Will be used to output digital signal only to Denon 3802 with Kefs and Rel Sub if thats any help.
    The RME Digi96/8 is the one to go for but a bit out of my price range so looking for cheaper alternative.
  5. Dick Scratcher
    Dick Scratcher
    I've had a Videologic Sonic Fury for years now and, with the exception of the long wait for XP drivers, has been of stirling service.
    Enter the Creative Audigy 2, bought mainly for the THX spec., which will be plugged into a cool Megaworks 5.1 THX speaker package. I'm waiting for the speakers to arrive so can't comment on the sound yet but I'm expecting BIG things.
  6. Branxx
    Branxx
    Nov 1, 2000
    801
    London, UK
    I recommend you look at www.staudio.com DSP24.
  7. petrolhead
    petrolhead
    Mar 29, 2002
    4,490
    71
    Newcastle
    +82
    Branxx, the link does not work. I wondered if you had the spelling wrong so typed in www.studio.com and well -- see for yourself :)
  8. MuFu
    MuFu
    Jul 24, 2002
    1,191
    41
    NW2, London
    +4
    Audigy 2 here.
    Settled on an A2 + NAD integrated amp stack after coming to the conclusion (through various demos) that I couldn't really top it without spending over £500 on a receiver. Very happy so far. :)
    If it's cheap digital output you are after then take a look at the Philips Acoustic Edge. Apparently very good in that respect.
    MuFu.
  9. petrolhead
    petrolhead
    Mar 29, 2002
    4,490
    71
    Newcastle
    +82
    Well I took the plunge.
    Was a bit of a fluke as my Creative DVD has started vibrating somit rotten so decided to buy a newun. Went on the Overclockers.co.uk site and decided on the Lite-On, I then had a look at soundcards and noticed the MAudio Revolution was now in stock so rangand just ordered. Nowt like messing about :cool:
    Crumbs, this can get obsessive.
    So all thats left if to await delivery, Scard, DVD Rom, Video Card, Quiet Fan and IRMAN ---- Phew I nee a lie down :smoke::D
    PS If it all goes S*&t face I can always sell the gear on this site :)
  10. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Our home computer NOT is not a HCPC.
    But we have a SB Audigy Platinium 2
    So far I have used Optical out for MD transfer, stereo in for video in sound for DVD mastering, and DVD-A analogue out.
    I'm afraid 32" TV is nicer than 17" LCD monitor!
  11. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,110
    Manchester
    +713
    I'll stick with my "Turtle Beach Montego Digital I/O ".
    It was in a close-out sale at Frys in Sunnyvale (Silicon Valley) about 26 months ago ($50).
    Never seen these in UK.
    Chris Muriel, Manchester.
  12. powergyoza
    powergyoza
    Feb 27, 2003
    I'm using a Stereolink 1200 external USB DAC. My crappy speaker & amp are the only things holding it back. It's stereo-only, but the DACs are supposed to be very good. Very friendly for my dual-CPU setup too. The SBLive!, Audigy 1/2, Turtle Beach Santa Cruz, Hercules xxx, basically all but the pro cards, tend to give dual-cpu machines the BSOD every so often.
  13. acs1
    acs1
    Aug 28, 2002
    Hove
    Petrolhead, thanks for the help, just noticed your remark about the revolution being in stock have waited ages for this, ordered one now, used to have a Sonic Fury, very good card
    Adam
  14. John_N
    John_N
    Philips Sonic Edge 5.1 SPDIF output to Nakamichi Amp..
    Afraid 84" projector screen is nicer than 32" tv... :)
  15. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    High Wycombe, Bucks, UK
    +59
    Hercules Game Theatre XP 7.1 ---> Arcam P75 (stereo) or Denon AVR2800 optical digital
    19" CRT monitor better than the only 14" TV in the flat!:smashin:
  16. petrolhead
    petrolhead
    Mar 29, 2002
    4,490
    71
    Newcastle
    +82
    Got the card seems easy to setup but no support for Win98 so went for Win 2000 as I could not setup WinDVD 4 to S/PDIF out.
