which sony?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by basem, Aug 17, 2003.
  1. basem
    basem
    Jul 31, 2003
    55
    I'm going to buy my first digital camcorder and after alot of research I'm going for either DCR PC120 or DCR PC105.I can get any of the two for about £600 but I'm confused which one to go for...any advice please:(
  2. owenw
    owenw
    Jul 19, 2003
    269
    Ireland
    The DCR PC120 has a better CCD chip (1.5 megapixels compared to 1.0 on the PC105 model) The DCR-PC120 comes with every gadget you can think of. I have the previous model PC110E but because I use a PC to edit I don't use the built in effects etc.
    you can't go wrong at 600 notes, I paid almost 3 times that for mine! It is a very nice camera. The limitations I have found are that because it has a small aperture it is useless in low light conditions. Mine doesn't have slow shutter speeds either which would be useful. If I was buying again I'd save a bit more and get a DCR-TRV950 3CCD semi-pro camcorder which is only a few hundred quid more than the DCR-PC120.
    Here's the DCR-PC120 spec from the Sony UK site:
    http://products.sony.co.uk/productdetail.asp?id=11_61_924
    and the DCR-PC105 spec:
    http://products.sony.co.uk/productdetail.asp?id=11_61_2734
    hope this helps,
    Owen
  3. basem
    basem
    Jul 31, 2003
    55
    thank you very much...i think i will go for the pc 120
  4. John F
    John F
    Jul 13, 2000
    3,497
    83
    Newcastle
    +110
    basem
    can ask where you have seen those prices as those are the 2 models i was thinking of getting
  5. basem
    basem
    Jul 31, 2003
    55
    you can get that price on ebay..but you need to be patient and check regularly
