  • Black Friday Deals
    Visit our Black Friday page for our frequently updated, hand picked deals on TVs and other tech.
Which Sony 43" 4K to buy
charp
having issues choosing the best of these
Reading past posts people say go for the 2016 XD but don't appear to be any for sale
I would also really like to have one with a silver bezel if possible - will be sitting 10' away (I know we should go for a bigger screen but our 50" is just too big) Have had Pioneer plasma and currently have a 6 year old Panasonic
Currys do some but they appear to be their own models and reviews are few and far between -
KD43XE8077SU (silver)
Richer Sounds do
KD43XE8004 (Black)
KD43XE7073 (Silver)
Are these any good?
Mainly use to watch HD over Virgin cable or Netflix - enjoy watching MotoGP to :)
any help welcome its a minefield out there even though I have limited make and size
Dodgexander
KD43XE8004 (Black)
KD43XE7073 (Silver)
Are these any good?
Not really unless you need wide viewing angles. In fact last years 43XD80 is better than those.
Why are you looking to upgrade with no UHD sources? I would keep what you have and look again towards spring next year, prices will be at their best then so you can pick up a lot more TV for your money...but it would also be wise just to keep with what you have anyway since you don't plan on using any UHD.
charp
I need a smaller screen my current 55 inch doesn't fit in the room so need to make a purchase now
Could go down to a 40" pioneer but the 43" sony seem the best fit for the room
don't need a huge viewing angle but wont be straight on as two sofas with tv between so I'd guess a maybe 30 degrees off angle
EndlessWaves
Any particular reason it has to be a Sony?
It looks like the 77 is the only silver variant of the XE80 so that's probably the one to go for, although if you're not in any hurry we should see lots of reviews of mid-range models over the next few months (and some price drops to boot).
charp
just needs to be 40-43 inch preferably silver
as good as I can get - budget not a huge issue as I do need to get within the next week or so ..
I said pioneer up there but meant Panasonic 40EX700B !
kenshingintoki
why would u want a 4k 43 inch screen? that really does seem a bit small to notice the benefits unless you are using it as a monitor.
I'd rather get a cheap older second hand 1080p sony with FALD than a newer edge lit 4k sony
charp
will be using as a monitor on the odd occasion I work from home - but mainly for watching Virgin HD TV and Netflix
Not had a disk player for years
kenshingintoki
if ur using it as a monitor and close to the screen, then def go 4k.
TBH all the models are so close in what they offer, I'd just go for:
a) the one u think looks best aesthetically
b) the one with the lowest input lag if ur into twitch shooters
c) the one with the most hdmi ports etc.
Dodgexander
The prices for those TVs right now are extortionate to say the least. The Samsung 43KS7500 was being sold for less than that last year and that was a UHD premium HDR TV.
These Sony's have IPS panels, no local dimming and barely any peak brightness for HDR...but they are priced very expensive. Why?
I saw a 65" Hisense K5510 for less.
