Which software to use ?
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by obrutau, Dec 27, 2004.
  1. obrutau
    obrutau
    Hi all,
    I'm just new at this and I bought a Sharp VLNZ8S camera. I would like to know how to bring my records from the camcorder to a DVD in order to see it in my DVD home player.
    And, of course, if there is a free way to do it, the better ;-)
    Thanks.
    Oscar.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,107
    Rainham Essex
    +2,380
    If you are useing Windows XP then you have MS Movie Maker that is a great program for capture & editing of your video.
    I would then recommend you get something like Ulead DVD Movie Factory 3 to create the DVD. This costs £30 or less online and a free 30 day trial can be downloaded from www.ulead.co.uk
    Mark.
  3. bignairy
    bignairy
    Mar 13, 2004
    96
    I agree regarding Windows Movie maker, but Nero 6 is better IMHO. :)
  4. obrutau
    obrutau
    Hi. I just tried the Movie Factory 3 (just the trial version: I will purchase it if it fits my expectations ;) ) and got a dvd with the content of one of my tapes, including a main menu and motion thumbnails in a DVD, but yesterday I tried to do the same with a main menu and a submenu with music and I only can hear it (no image at all) in my DVD player (although I can see it perfectly in my PC).
    I think these are the only differences between both tests, but now I can see the first DVD, but not the second one... Any clue about what can be happenning ?
    Thanks and regards.
