Question Which smart thermostat?
Discussion in 'Smart Home, Climate Control & Security Forum' started by 1pudding1, Mar 11, 2018.
    1. 1pudding1
      1pudding1
      Jan 21, 2003
      551
      28
      Bodmin
      +33
      Hiya. I've just bought a commuter crash pad/2bed flat for when im at work away from home. I work a fixed pattern of 5 days on/4off/5 on/3 off. The work hours vary completely too so there's no way to schedule the heating to heat the flat when i'm actually there.
      At the moment, it's got a recent (3yr old) Ideal combi-boiler, which is set to always on. This is then connected to a 7 day Horstmann Centaurstat 7, which is a simple 6 point timer for each day of the week. The always on on the boiler is fine, as the hot water is just on demand, but the heating via this thermostat is heating the flat a lot when im not there.
      I could just turn the thermostat effectively off via the time setpoints, and override when im actually there, but then i'd constantly be coming back to a cold flat. Ideally I want to replace the thermostat with something smart, that I can either access remotely from my phone in advance of going to the flat, or perhaps by geolocation when i get within 5/10miles to get the heating on. And also would have some kind of away/holiday mode and a fall/setback temperature.
      Any recommendations on what to replace the thermostat/timer with, as there seems to be tons out there from fairly basic simple and cheap stats that might do what i need, to the top of the range such as Nest etc which as supposed to recognise your habits/routines etc (but which would be completely wasted in my situation i guess?)
      Cheers.
    2. Lesmor
      Lesmor
      Jul 25, 2007
      5,479
      2
      167
      Aberdeenshire
      +3,309
      I like my Hive system
      Great for going on holiday schedule
      Works perfectly by phone app
      You would need to check compatability with your heating
      Geolocation by IFTT
    3. 1pudding1
      1pudding1
      Jan 21, 2003
      551
      28
      Bodmin
      +33
      Sounds good. Works with standard combi-boiler and thermostatic raditor valves? What parts came with it, was it a wall unit and then something/relay etc to connect to the actual boiler?
    4. Lesmor
      Lesmor
      Jul 25, 2007
      5,479
      2
      167
      Aberdeenshire
      +3,309
      As i said you would need to check compatability with a combi boiler
      I had a honeywell controller so the hive box was a straight swap
      Then you have the Hive hub connected to your router
      Also a portable battery powered thermostat
    5. Bryn1
      Bryn1
      Sep 28, 2011
      684
      43
      +150
      Also look at 'nest' will do all of the above
    6. scarty16
      scarty16
      Jul 1, 2003
      1,504
      +360
      Tado is another option that looks good. I have a Nest, as I got it free.
    7. Lesmor
      Lesmor
      Jul 25, 2007
      5,479
      2
      167
      Aberdeenshire
      +3,309
      Yup
      I also considered Nest but the thermostat is hardwired so I went with Hive
    8. Jamie
      Jamie
      Jun 27, 2007
      5,190
      2
      Harrogate
      +1,330
      Nest isn't hardwired if you don't want it to be.
      The thermostat itself connects wirelessly to the heatlink which is the box of tricks wired into your boiler and just needs USB for power.
    9. TylerDurden
      TylerDurden
      Nov 6, 2005
      4,132
      +616
      Do you have a wired thermostat in the property ? If so I'd go for a Netatmo, super easy self install, from then on controlled via phone app / web browser
    10. 1pudding1
      1pudding1
      Jan 21, 2003
      551
      28
      Bodmin
      +33
      Yeah, its a wired thermostat, so wired would be good as it removed the need to bother with batteries. Tado and Hive looking good atm, Tado especially looks like a really easy install with it just replacing the thermostat and no need to wire anything into the boiler.
      Will look at Netamo, which item in particular?
    11. mushii
      mushii
      Apr 3, 2003
      1,857
      116
      Stoke On Trent
      +1,027
      Nest user here. Self install, 40 minutes. Does everything that I need, easy to use, learns my patterns of occupation, geofences, compensates for weather, detects occupation, keeps my home at the right temperature at the right times and looks cool. Enough said.
    12. Jamie
      Jamie
      Jun 27, 2007
      5,190
      2
      Harrogate
      +1,330
      Tado still uses batteries. To be fair my old school British gas programmable thermostat uses batteries too.
    13. TylerDurden
      TylerDurden
      Nov 6, 2005
      4,132
      +616
      https://www.amazon.co.uk/Netatmo-smart-thermostat-works-Amazon/dp/B00GWKW8SY
    14. 1pudding1
      1pudding1
      Jan 21, 2003
      551
      28
      Bodmin
      +33
      Thanks all. Ordered the Netatmo earlier, hopefully arrives tomorrow before i go back to the new place on Weds morning so i can install it this week.
    15. TimmyH
      TimmyH
      Oct 19, 2004
      154
      +19
      I'm definitely technically deficient and I fitted my wired Netamo in a few minutes. If you are unsure of the wiring colours, email them a photo of the wires and they will tell you which way to fit it. If you want your heating on at 6am it can either switch it on at 6am or there is an option that it can come on earlier so that the desired temperature is attained by 6am (or whatever time you set it to).
    16. nrees87
      nrees87
      Nov 26, 2017
      197
      46
      GB
      +149
      Hive products don't play well with others - so for me it isn't even a consideration.
      I've got a Logitech Harmony Ultimate Hub & Remote, along with the Hub Extender for controlling Zigbee / ZWave smart doo-da's. Tado is the one that I keep coming back to - mostly because of it's integration of smart TRV's which can control the temperature in individual rooms. It's not a cheap investment (about £900 for a 3 bed, 2 bath terrace) - but I'm hoping it will work out.
    17. Fulltopuk
      Fulltopuk
      Oct 24, 2004
      407
      28
      +29
      Just a thought but check your enery provider. Some are doing offers for smart thermostats, mine for instance are offering free Nest including fitting.
    18. 1pudding1
      1pudding1
      Jan 21, 2003
      551
      28
      Bodmin
      +33
      Well, i got to the new place last night and the internet had already been activated and turned on when i connected the new router, so decided to give it a crack installing the new Netatmo. Done in about 20mins :) All working nicely now and set up IFTTT so when i leave it drops back to the away temp of 12deg.
    19. djsgrant
      djsgrant
      Jan 4, 2009
      3
      +6
      I have used the TADO with a combi-boiler and it worked beautifully. Easy to self-instal with your setup.
    20. paulrw
      paulrw
      Jan 3, 2009
      462
      28
      Essex
      +99
