Which Sky+ Digibox?
Discussion in 'Sky Digital TV Forum' started by lapman22, Sep 4, 2004.
  1. lapman22
    lapman22
    Sky+ install is scheduled for Monday. When I asked the CS rep which digibox will be installed , He said to speak to the installer... :confused:
    Assuming I'll have a choice , Which box to go for? Make , model , etc would be very helpful.
    Also , How can you tell if it's V1 or V2?
    Cheers,
    Lapman.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Under normal circumstances you won't have a choice, the installer will give you what he has in the van.
    The V1 hasn't been produced for about 18 months, there are no new brand new sealed units in SKY's supply chain, the only v1's supplied now turn up as refurbished units. You will receive either a brand new PACE v2 or the new Amstrad variant.
    Pictures, articles etc over at Plusworld.
  3. lapman22
    lapman22
    install was completed as scheduled today. digibox is a new Amstrad DRX180 PVR2.
    1. Is it the V2 box? Is it better than the Pace?
    2. OS ver 1.3.0BH
    3. Sky+ ver 1.26.v3
    4. Noticable problems:
    - voice sometime doesn't work when changing channels. you need to change to another one to get it back.
    - very slow moving between channels.
    5. Are these problems likely to go away once the ver. is updated?
    6. Any way of updating manually?
    Cheers.
    Lapman.
  4. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    20,417
    In a secret location with Jennifer Lawrence
    +7,249
    You will notice it is a lot slower moving between channels, if you have just upgraded from Sky. Probably something to do with the autorecord. You get used to it after a while.
  5. lapman22
    lapman22
    thanks. How do I update the SW versions manually?
