Which Sky+ box ?
Discussion in 'Sky Digital TV Forum' started by ctcrm, Jul 22, 2005.
  1. ctcrm
    ctcrm
    May 6, 2003
    134
    The sky lad is coming next week to upgrade the system, if i was lucky enough to be able to blagg a choice of box which would be the best one to go for bearing in mind I want to u/g the hard drive in the near future ?
  2. Astaroth
    Astaroth
    Jun 22, 2004
    2,258
    63
    London
    +101
    The pace v2 is generally considered the best box on all grounds however you do not get a choice of box (even if the sales advisor says you will) unless you know the installer - but then if you know them then they should be able to answer this question for you :)
  3. ctcrm
    ctcrm
    May 6, 2003
    134
    well lets say there was a pace v1 and an amastrad box... ??
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Well, I'd choose the Pace V1.
  5. ctcrm
    ctcrm
    May 6, 2003
    134
    cheers for that.:)
