Which sky box
Discussion in 'Sky Digital TV Forum' started by MarkTy, May 27, 2005.
  1. MarkTy
    MarkTy
    May 20, 2005
    163
    16
    I am about to take delivery of a Pioneer PDP 505XDE screen.
    I will be getting a sky HD box when they come out, but in the meantime what will be the difference of feeding in a Sky plus box, and just a normal sky box (I realise I will only get DD sound from the sky plus box), but does sky plus box offer better image connections ? (In which case I might get hold of one for the next few months)
    Thanks everyone
  2. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    AFAIK, the picture quality from a Sky+ should be the same as a standard box (unless, of course, you get an Amstrad + box in which case you may get the banding problem!)
    John
  3. gsxr750steve
    gsxr750steve
    Sky+ has Optical Audio output which the normal one (at least my normal one) doesn't have. So if you are connecting to a surround sound system you can connect your audio into the ss amp and the video, via the standard Scart connector, to the Plasma.
    Better sound, same picture.
