which sky + box ?
Discussion in 'Sky Digital TV Forum' started by pezzer, Nov 10, 2004.
  1. pezzer
    pezzer
    Jun 9, 2004
    187
    West Sussex
    Sky just replaced my faulty originalPace DVB Sky+ box with a new one - the same model but with V2 software ( the bigger box with black centre panel)
    I was hoping it would be a new generation model but the installer said the older one was more reliable - is this true [inappropriate word removed- lynx].
    Any views on which is the best sky + box ?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +975
    Well my original version1 PACE is still going strong and it's over 3 years old:)
    To be honest both the current PACE and AMSTRAD models have had problems which annoyingly are not universal but tend to be model/revision specific, it's that unpredictablilty that makes saying box A is the best so difficult:)
  3. Jules
    Jules
    Oct 11, 2000
    5,534
    +1,005
    I have a V1 and V2 machine.
    IMO, the V1 machine IS better. Its better built and quieter.
    I also prefer the styling of the original box, as it matches normal sized AV gear.
  4. bobcar
    bobcar
    Oct 3, 2004
    708
    +21
    To be honest it doesn't really matter what model you get. If it works then its good, the nightmare scenario is when you keep getting refurbished (not fixed) models as replacements. I think if the refurb you get is one with a definite prev failure you're ok, the problem is if it had an intermittent (difficult to reproduce) fault and it just goes back into the loop.
