Which size would be best from 6-8 feet?
Discussion in 'LCD & LED LCD TVs Forum' started by blazevxi, Feb 10, 2009.
Tags:
  1. blazevxi
    blazevxi
    Sep 22, 2008
    94
    +5
    So I should be getting a new TV soon to set up a HT with, and I was wondering what best size would be good from about 6-8 feet viewing distance?
    Im going between 32, 37 & 40"
    Be used for PS3 (Gaming & Bluray), SD DVD & SD cable.
  2. vickster
    vickster
    Jun 25, 2006
    17,284
    +1,921
    37" max, any bigger and you'll get grainy SD IMO :)
  3. simon11
    simon11
    Apr 8, 2008
    244
    +7
    Unless you buy a top of the range Philips Ambilight. Then you can go up another size!
  4. scimg
    scimg
    Jul 31, 2008
    84
    +4
    Don't worry about that, we are in the middle of a credit crisis.
  5. holiver
    holiver
    Apr 21, 2006
    235
    Hampshire
    +20
    Which is irrelevant if you have cash and job security.
