which signal on AE300
M
mikeq
Hi all,
Is there a secret menu where I can tell what signal is being fed to my projector, I'm looking for progressive/interlaced PAL/NTSC
Mike
CrispyXUK
it de-interlaces the signal if you send it interlaced anyway
M
mikeq
Thanks CrispyXUK, I knew that one.
Reason for asking is I have my signal fed through component from my KISS DP-500 (which is progressive enabled) and I want to check that it is feeding what I think (hope) it is feeding.
Mike
Zone
Mike
IIRC menu>picture options at the bottom of the screen it indicates what feed its receiving ie interlaced or progressive, it doesn't indicate whether its a NTSC/Pal feed AFAIK but then again the region of the DVD indicates that!
Benrudd1
as the above says go into the picture menu, at the bottom it will have one of the following
525i = NTSC interlaced
525p= NTSC progressive
625i= PAL interlaced
625p= PAL progressive
I think I have the numbers correct if not its 500 and something for NTSC and 600 and something for PAL. (can't be bothered to start up the projector to test):D
Podcast: LG C1 OLED First Thoughts + JBL Synthesis SDR-35 Review, TV Show & Disc Reviews & more
