which signal booster?
peps1
Im right on the coast, so my digital signal is not amazing as is, but add to that I have a dodgy arial on-top of a huge Georgian building with no access to the roof (converted into apartments).
I get most channels on a good day, but keep loosing the BBC channels and some of the news channels.
So was wondering which signal booster will really make a improvement?
grahamlthompson
Not sure what a doggie aerial is :D. Have you access to the coax downlead in the loft ?
peps1
:D epic spelling mistake, even by my standards!
Unfortunately I dont have access to the coax lead :(
(guess replacing it with a a decent coax would do better then any booster, but just not an option)
grahamlthompson
It's worth trying a simple plug in booster behind the TV. If you could get access to the cable a masthead amp mounted as close to the aerial as possible with a power supply behind the TV would have been a better option. Guess your aerial will be great to watch the Crufts coverage :)
