hi all
i am looking to get a cd player but was unsure of which route to go
currently i have a denon 2105 av receiver, mission v62 floorstanding speakers (used for HC with 2105) a pair of v60's not being used.
i have a budget of 300-400
the first option i have is to buy a cdp and amp, something like the nad 320bee etc and use the v60's
the second is to do the same as the first but use a speaker switcher box and sell the v60's and use the 62's
the thrid is to use the ext inputs on the receiver for just a cdp and sell the v60's and put the extra towards the cdp
my living room isnt that big but i dont have to bother about keeping a other half happy at the moment, and using a totally different setup it might look at bit cluttered with all the speakers but which set-up will give the best SQ
thanks for any help
cheers lee
thanks for any help
cheers lee
