which set up?
Discussion in 'Projectors, Screens & Video Processors' started by karkus30, Aug 10, 2002.
  1. karkus30
    karkus30
    Jul 29, 2002
    13,997
    +1,236
    I have just set up my first PJ, its a Sanyo PLV30 projecting onto an owl electric screen, with a PAL progressive scan player. Fantastic results straight out of the box. But I am wondering with all the settings for Croma, sharpness etc on the Player and similar on the projector. How do you get the best image, which unit should take presidence on set up? Need to start fiddling now or should I leave it as it is? I have read about set up discs, so I will probably get one of those.
  2. Messiah
    Messiah
    Apr 22, 2002
    7,624
    +338
    Just out of interest, what prog scan player are you using?
  3. karkus30
    karkus30
    Jul 29, 2002
    13,997
    +1,236
    Philips 962SA import, I have posted a small review on the DVD players forum.
  4. Kramer
    Kramer
    Get Avia.
    Leave the PJ on default settings & adjust the settings of your DVD player.
    Then finish off with your PJ settings.
  5. karkus30
    karkus30
    Jul 29, 2002
    13,997
    +1,236
    Cheers,
    Avia it is then. How long does it take to complete the set up ?
    Where is the best place to buy?
