Which seperates?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by daz123, Feb 6, 2009.
  1. daz123
    daz123
    Dec 26, 2008
    67
    9
    Manchester
    Hi Guys,
    I'm looking to upgrade my pioneer mini system to some separates, looking at a Tuner and CD Player both in black if possible.
    I would like to integrate the separates with my yammy 763 and Canton CD102, I will be upgrading the two fronts to floor standers in the future. So for now i wont need a power amp i think.
    The budget is around £300.00 not a lot i know but thats it.
    Advise on connecting them up to my yammy would help also.
    Any suggestions would be greatly appreciated.
    Cheers, Daz.
  2. teishu
    teishu
    Sep 8, 2008
    129
    Burton Upon Trent
    +17
    I would suggest the NAD [email protected]£156.55) and then either the Arcam DiVA T61 @ £127.19 or to stretch you budget slightly the NAD C425 @ £176.12
    All of the above are at superfi..
    hope this helps.
  3. daz123
    daz123
    Dec 26, 2008
    67
    9
    Manchester
    Sorry guys forgot to mention a DAB Tuner would be preferable.
  4. daz123
    daz123
    Dec 26, 2008
    67
    9
    Manchester
    Anybody else have any views?
  5. Marvt74
    Marvt74
    Feb 13, 2005
    777
    28
    Manchester
    +47
    Dab tuners are quite pricey so you might wish to look second hand if thats your preferential route.
  6. cunny678
    cunny678
    Jul 2, 2007
    5,701
    Manchester
    +693
    Your could always consider using your DVD to play music and using a seperate DAC (digital to analogue convertor). If you do a search on here for "beresford" you will find some useful info on that DAC which by all accounts is pretty good.
    Basically using the external DAc should provide better sound quality than most budget Cd / DVd players. You would in effect only be using the DVD as a transport and the DAC to process the sound. You will need to check you have suitable optical connections on your DVD for it to work!
    Just a suggestions:smashin:
  7. cunny678
    cunny678
    Jul 2, 2007
    5,701
    Manchester
    +693
  8. daz123
    daz123
    Dec 26, 2008
    67
    9
    Manchester
    what do you guys think about maybe going down the mini system route again maybe something like:-
    TEAC DR-H300DAB-BLACK
    Or
    DENON DM37DAB-BLACK
    Or
    With a compromise with the colour the DENON DF102DAB CD/RECEIVER MINI SEPARATES SYSTEM
    This may be the only way to stay on budget, No to sure how to wire one up to my Yamaha DSP-763 so i can use the Canton 5.1 system.
