Which scart ?
Discussion in 'Plasma TVs' started by LCDRulz, Dec 23, 2004.
  1. LCDRulz
    LCDRulz
    At the moment I'm using a couple fully wired scarts connect between:
    DVD ->Sky+ ->RGB/VGA to PW6
    I only need RGB as all the sound is via Digital Audio. I could get RGB only scart cables, would these offer a better solution ie. fewer signals across the scart - lower crosstalk ?
  2. stuart07970
    stuart07970
    Sep 28, 2004
    2,266
    Slough
    +185
    I can highly recommend the QED Squart RGB 'special edition'.
    There was one for sale on here a week ago, about £25ish BARGAIN!
    Although they are heavy and the cable a bit inflexible, they are a superb cable, with areally good, solid grip!
    Good Luck
    Stuart
