Which Scart?
Discussion in 'Cables & Switches' started by swarrans, Oct 27, 2004.
  1. swarrans
    swarrans
    Dec 21, 2001
    409
    16
    Kent, UK
    When I set up my new equipment I'm thinking of ditching the 3 x 3m scart to scart leads and replacing them with shorter ones as they don't need to go all the way to the TV (will be using a plasma with component to VGA from Denon 2805 so I just need 2 scarts - one from Sky box to Tivo and one from Tivo to JS RGB/component converter).
    After that long intro(!) I need advice as to which scart to scart leads to get - they only need to be 1m long max and I've seen an IXOS one at Amazon for £14.99 (but doesn't say which model) or the Thor one in another thread £17.99 from Play.com.
    Anyone have any views/preferences/other recommendations?
    Ta,
    Simon
  2. Kramer
    Kramer
    Don't think you can go far wrong with the Thor ones, available from forum sponsor TV Cables......£16.99 IIRC.
    :smoke:
