Which Scart RGB To VGA adapter for Sky+
Discussion in 'Plasma TVs Forum' started by Baldster, Jun 14, 2004.
  1. Baldster
    Baldster
    May 6, 2004
    115
    +3
    Have decided to buy a Scart RGB to VGA adapter to improve picture from Sky+ box to a Panny PW6.
    Have heard Dr John's recommended ...
    http://www.js-technology.com/rgb-vga/index.htm
    ... but have also seen significantly cheaper one at Lektropacks ...
    http://www.lektropacks.co.uk/product/technical.asp?dept_id=67&sku=592
    Anyone using either of these and suggest what would be best VFM. Or any other alternatives ? Don't want to compromise on quality for sake of a few quid.
    Also any guidelines on getting a quality-enough VGA lead ?
    Thanks, The Baldster.
  2. Member 6435
    Member 6435
    Dec 18, 2000
    1,518
    Tunbridge Wells
    +324
    Baldster
    Although I'm unable to provide a direct comparison between the two products mentioned in your post I would encourage you to take the JS Technogy converter route. :smashin: You will not find a bad word spoken about them on this forum as the build quality and performance of these products is excellent. I am sure you will get a number of forum members echoing these thoughts.
    Regards
    Alastair :hiya:
  3. SilverPenguin7
    SilverPenguin7
    Mar 4, 2002
    443
    +21
    Yup, I agree. I use the JS RGB2VGA and it gives a rock solid picture. I'm surprised just how good some channels on sky look!
  4. Wazy
    Wazy
    Also John sells a good quality VGA cable on his site as well, I got the 3m one for £40. Picture quality is superb on $ky :)
  5. nobbydog
    nobbydog
    Jun 19, 2003
    262
    Comfy basket in the utility room
    Yep, me too.
