Which SCART for my new FX66?
Discussion in 'General TV Discussions Forum' started by mozster, May 7, 2003.
  1. mozster
    mozster
    Hi folks,
    Got a new Sony 28" FX66 and wandered if there was any merit in upgrading my SCART lead? I currently use a bog standard shielded lead which was about £13 initially if I can remember correctly.
    Also noticed watching ITV1 via Sky Box tonight that a wide black vertical band appears either side of the picture - wasn't there on terrestial ITV though!!!
    Mozster
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    A better scart will improve picture especially the Sky menu system, Look at Scarts from QED and Thor as well as others Lektropacks do some nice ones as do Monster. Depends how much you want to spend!
  3. mozster
    mozster
    Thanks for the info, do I order these over the web or will I be able to get them from the likes of JL/Comet etc?
    £30 mark I thought for a lead?! :)
  4. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    9,022
    Babel Sensurround
    +207
    pressing services then 4 then 1 then changing from 16:9 to 4:3 will get rid of these just remember to change it back when the footy is off
  5. CYRUStheVIRUS
    CYRUStheVIRUS
    Jan 25, 2003
    1,408
    41
    Berkshire
    +16
    look in special offers at THOR scarts, they are well built and recommended as an upgrade.
  6. Mick da Miller
    Mick da Miller
  7. neilybealy
    neilybealy
    Jul 9, 2001
    1,556
    48
    Kent
    +57
    i bought 2 of the thor scarts from the above link and highly recommend them:cool:
  8. ajbm325ic
    ajbm325ic
    I bought all my leads (3 x 5m flat scarts,75Ohm sub cable,banana plugs etc) from this guy. (Hyperlink below)
    They are Tech-link metal cased with gold connectors fully pinned and individual oxygen free screening. I'm no expert but am very impressed with the build quality, picture and sound.
    Send him an email as he was very helpfull and sells a vast range of quality cables and connectors at excellent prices. I found him less than half price of many retailers for the same cables.
    By the way I'm not connected in any way - just impressed with service and kit.
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=3022898442&category=298
  9. mozster
    mozster
    Thanks for all your input folks, have purchase 3 THOR ones.:smashin:
