Which Samsung Soundbar
Discussion in 'Soundbars, Soundplates & Soundbases' started by Artista, Aug 28, 2018.
  1. Artista
    Artista
    Aug 27, 2018
    4
    Europe
    Recently I've decide to replace my AV-receiver (2013) and speakers with a soundbar, as with newborns walking around the place I couldn't find a way to safely (for both the children as well as the speakers) position my speakers, plus the fact that the AV-receiver had limited connectivity options.
    Now, I thought a soundbar might be a good replacement, as it looks minimalistic, supposedly is capable of delivering good sound and would be “more resistant to the children”. In considering a soundbar, so far I've seen some great reviews of the Samsung soundbars, but am a bit lost.
    Basically, I'm considering a Samsung K850, because of a) the price b) it being slim c) the materials used d) that it features a subwoofer and e) that it doesn't feature additional satellite speakers; the latter would require additional hassle with positioning them etc., and I do not have a symmetrical wall on the back where I can put them up.
    In terms of needs, my previous AV-receivers featured some form of Dolby Surround, which, in the end, because of the speaker setup, I never really used; instead, I used them in stereo with two speakers only; as such, I am used to the richness in sound of full-size speakers. However, when watching movies, occasionally, I would appreciate some form of surround without the additional speaker setup. Additionally, I also would be frequently use the soundbar to stream sound (e.g. YouTube) or music (e.g. TuneIn, Spotify etc.).
    When going through the different Samsung soundbars, I figured out that the prefix in the model number identifies the year in which the soundbar was released: K = 2017, N = 2018. However, in terms of pricing, when looking at the K850 and the N850, there is a huge difference in price with the N850 retailing at almost double the price of the K850.
    And then there are also the Sound+ soundbar models (e.g. the MS750), which I believe are only different in that they do not feature a subwoofer, that are substantially cheaper as well; based on being used to regular speakers, I believe that a subwoofer would be required in combination with a soundbar to match the same sort of sound.
    So to summarize, I’m a bit lost and would appreciate it if you can share your views here as well.
  2. Sleeky
    Sleeky
    Dec 9, 2016
    Northamptonshire
    Hi, what did you decide to do in the end? I'm finding myself in exactly the same position
