Which Samsung LE32xxxx ???
Discussion in 'Samsung TVs Forum' started by JuniorJ, Mar 13, 2006.
Tags:
  1. JuniorJ
    JuniorJ
    i'm interested in purchasing a 32" samsung LCD TV, but which one? and what are the differences? or what's the best?
    LE32R41BDX
    LE32R41BDX
    LE32T51B
    LE32M51B
    LE32M61B
    :lease: please help, because i really am confused on what one to buy...
  2. tjxkeith
    tjxkeith
    Mar 8, 2006
    28
    3
    I to am thinking of the Samsung. Bellow is what I think the differences are but could be wrong. You could try downloading the manuals from Samsung website.
    Basicly B= std uhf Tunner BD= Freeview Tunner
    Think your 2nd model was suppose to read LE32R51BD
    The 41 or 51 are cosmetic changes casing
    LM32M I think are the new models
    LE32T51B Possible German as only found them on Ebay Germany.
    Cant belive what people are paying on ebay when you can get them at £720 with Freemans 20%. If only JL would pricematch you get the 5 year warrenty.
  3. dafran
    dafran
    Feb 1, 2006
    +17
    Just put the LE32T51B in front of your list and you have put them in the right order concerning the quality with the LE32T51B the least and the LE32M61B the newest and best Samsung LCD.
    I've bought the LE32M61B after seeing the R51 (same as the R41, but other design), the M51 and the M61 running next to eachother in HD. The M61 was clearly the winner. The colors are better and it's also the fastest panel which is important for gaming and fast movements like football etc.
    If you got the extra money to spend, go for the LE32M61B.
  4. lexmeister2
    lexmeister2
    Nov 18, 2005
    149
    +3
    Yep if you've got the money, M61 has no competition
