Which Router ????
Discussion in 'PS Vita Forum' started by jerkyboy, Sep 2, 2005.
Tags:
  1. jerkyboy
    jerkyboy
    I want to get a Router so that I can connect my PC and Xbox via Ethernet cables, and be able to surf the net wirelessly on my laptop and PSP.
    Can anyone recommend which model to go for.
  2. BuFF DaDDy
    BuFF DaDDy
    Jun 2, 2005
    3,287
    +146
    I use a 3com router at home, I use it to surf the net on my centrino laptop and now my PSP, the PSP detected it without any problems what so ever.
    No I can sit in any room or in the garden (Like today as its been nice) and surf the net!
  3. peteyoung
    peteyoung
    Mar 2, 2005
    97
    11
    Staffordshire
    ive got a linksys wrt54g router, its affordable, wireless b+g for both ur psp and laptop, 54mbps which is great for transferring files over ur home network, 4 ethernet ports for ur wired devices and finally really easy to use!
  4. jerkyboy
    jerkyboy
    Thanks Guys.
    I have Telewest Cable Broadband, will these routers work OK with this ?.
  5. dimples
    dimples
    Aug 6, 2005
    252
    Newcastle upon Tyne
    +9
    Hey Pete,
    I have the same router but have no idea as to how to get the psp connected through it, any chance of giving me some pointers on it?
  6. fozziebear39
    fozziebear39
    Jan 3, 2003
    1,009
    Newton-le-Willows
    +49
    No. The majority of combined ADSL modem, wireless router are for ADSL phone lines. A specific 'modem' is required for cable.
    If the box that your broadband comes out of has an ethernet port then you can just plug a wireless acces point into that.
    I have a Netgear DG834G which works great with PSP. That plugs into BT line. They do a version the WGR614 which seems the same model apart from the modem. Ask Telewest what they support. Any wireless system should work with PSP.
  7. chrislad
    chrislad
    May 6, 2005
    5,659
    83
    Rep. of Ireland
    +141
    All you have to do, literally, is have a wireless network set up. If you do, just get the WEP key. That can be accessed via the router IP address (normally found in the manual). If you don't have a wireless network set up, you'll have to set one up via the router IP (or if there is router software), and follow the same steps (ie WEP Key)
  8. dimples
    dimples
    Aug 6, 2005
    252
    Newcastle upon Tyne
    +9
    Thanks. I discovered that all I needed to do was turn on the wifi switch on the PSP! But when I look at the info of my connection it says security=none, which I will have to resolve at some stage!
  9. peteyoung
    peteyoung
    Mar 2, 2005
    97
    11
    Staffordshire
    to set up security just go to 192.168.1.1 then select wireless then wireless security and u can choose the type u want, for u either wep or wpa-tkip, wpa is more secure though, either way whichever you choose just enter a code or phrase of your choice then enter that on your psp
  10. dimples
    dimples
    Aug 6, 2005
    252
    Newcastle upon Tyne
    +9
    Thanks Pete :thumbsup:
