Lennyz
I am hankering after a front projection setup but I have a dilemma...
At the mo' I have a lounge that has my plasma installed but will be re-decorated in the next 12 - 18 months. I plan on doing loads of alterations in there as it has yet to be made how I want it ( we have only been here 2 years so far and time has been tight ) The lounge is pretty big around 6.5metres X 3.6m.
There is also another room I could use which is currently used a playroom for my son but I could use it in the future as a dedicated HC room...the only issue is that it is considerably smaller i.e 2.5m x 4m.
The lounge is slightly L shaped and the screen would be sited across the narrow end with seating at the opppsite end of the room as it is currently ( facing the plasma ).
The only issue with the lounge is so I really want a projector hanging from the ceiling? Would I be better going for the smaller rectangular room and fill one end with a screen and not have to worry about what equippment goes in there??
Is 2.5 X 4m too small for a dedicated room.
Anyone out there with dedicated rooms of this size
opinions folks. Ta
opinions folks. Ta
