Which resolution is best?
Discussion in 'Plasma TVs Forum' started by Jepsen, Feb 18, 2005.
  1. Jepsen
    Jepsen
    Which resolution is the best?
    1024 x 1024
    1366 x 768
    or even
    1280 x 768
    Is 1024 x 1024 the same as 1024 x 1024i ?
  2. Loada
    Loada
    Mar 4, 2003
    593
    Guisborough, North Yorkshire
    +51
    1366x768 is 16:9 at high-def and would POTENTIALLY give the best results with a 1:1 pixel-map (providing it was possible with the display).
    1280x768 is ARGUABLY (and there will be some :)) the next best as it offers a 720p picture with minimum scaling.
    1024x1024 is the resolution that ALiS-based screens use. It's not as straightforward due to the way that technology works.
    That's probably not of any use, but there you go :)
  3. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    1024x1024 is an ALiS panel and is only 1024x512 but the horizontal lines are doubled making 1024x1024. Not good for Hi Def as you need at least 720 horizontal lines.
    1366x768 is 16:9 and is good for Hi Def. Normally seen on the latest LCDs.
    1280x768 is 15:9 and again is good for Hi Def but the 15:9 panels in LCD terms are an older style panel. If you find an LCD with this, the technology could be 12 months or more old. Don't know about Plasma though.
    Richie.
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +271
    That is just not true ! The odd and even pixel rows are scanned sequentially, as in a conventional CRT. Are you saying that we've been watching 312.5 lines on our CRT's all these years ? :rolleyes:
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Hitachis do in fact use all of their lines as described, but the scaling/interpolation is a dark mystery. The internal processing knows no rhyme or reason, you either love it or hate it. Actually when watching TV on your plasma you'd be hard pressed to know which res. you were looking at, other things are at least as important as resolution.
