Which Replacement system..Help plse
M
mitto
I now have a JVC THA 35R which I'm getting rid of due to very noisy internal fan, looking at replacing with either Sony DAV550, HTP 1100, Toshiba SD43HK or Panasonic two tier SLDT310 & SADT310. Don't want to make another mistake, coule any-one help out with reviews/comments any input would be appreciated.
Looking to pay up to approx £350.
Many thanks.:hiya:
M
mitto
Reasonable volume must be able to play dvdr & cdr/cdrw's, generally a good allrounder. One with smallish speakers, nothing too in your face.
TV is a 28" flat screen nicam s/sound, nothing special I'm afraid, waiting for the price of plasma screens to come down!
jaymac
The 310 fronts are good but pretty bulky and no scart/rgb. have alook at the pioneer 99 It,s downto about £350 and will play everything including Sacd and Dvd-audio
bonzobanana
I'd also recommend the basic Pioneer NV-99 system. It provides good volume and should be pretty good with dvd-r and cdr/cdrw. It has excellent picture and sound performance.
