Quantcast
Which remote receiver?
CrispyXUK
hi all,
need to et my HTPC remoted up, was wondering what is the best solution as I have a kameleon 6in1 remote and am soon purchasing the Nebula DIGI-TV card which has a remote receiver with it, will it work with my Kameleaon? or do I need something else.
wyerd
AFAIK, the remote controller supplied is a One 4 ALL type, the same as the Kameleon. You program the VCR button with device code 0033 to get it to work with the supplied IR receiver.
CrispyXUK
Nice one brother
