Which remote controlled lights should I go for?
Discussion in 'Home Cinema Buying & Building' started by MuffKing, Nov 23, 2004.
  1. MuffKing
    MuffKing
    I want to control a main ceiling light which is switched by the wall switch as well as sunken ceiling lights and a pair of wall lights via one remote control, although this would need to be done via RF to control the wall and sunken lights.
    I've seen an IR wall switch and 4 switch remote control, but as I want to control 2 other sets of lights which could not be controlled by IR (unless there is a 3-way IR wall switch). Does anyone know of anything that would do the job???
  2. ntslik
    ntslik
    Jul 26, 2002
    620
    Cambridgeshire
    +10
    Hi, check out the rako range, as these all work on RF and very easily installed and adapted
  3. Docta teef
    Docta teef
    Nov 21, 2003
    1,262
    Manchester
    +56
    I would look at X10 where you can use RF or an an IR converter
  4. JLA
    JLA
    May 22, 2008
    54
    11
    +13
    Try looking at Home Easy :thumbsup:
    These are available from B&Q so if anything goes wrong you can replace them very easily. They are also retro fit so no additional wiring or week long instalation, you could install this within a few hours.
    They also have a website just search home easy in google. :clap:
  5. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    I'd second the rako recommendation. I've had a basic X10 solution and now a rako one - the latter is far superior. easy retro fit with minimal time/experience needed to do the job. not the cheapest way but very professional and very reliable.
  6. fasterfords
    fasterfords
    Dec 24, 2006
    96
    +3
    I've just bought the basic kit from B&Q and it works really well.
    I will be adding the dimmers next and some more sockets.
    The basic pack with 3 sockets and 1 remote is only £20 too
