Which Recorder to buy?
Discussion in 'Blu-ray & DVD Players & Recorders' started by RickB, Oct 11, 2003.
  1. RickB
    RickB
    Guys,
    Having finally decided that I could do with a DVD recorder, I have narrowed my choice down to a couple - anyone have any comments as to which to buy or should I look at something else?
    I only have the following pre-requisites - must have firewire and must be able to write to DVD-R's - purely because my PC based writer is -R/-RW and it would make sense for me to avoid having to buy a second type of disk (plus I know my DVD players all work with -R/-RW)
    1. JVC DR-M1.
    2. Panasonic E60
    I did look at the Sony RDRGX3S - but it doesn't seem to have firewire.
    Any preferences? and does anyone know where I can the best prices - RS want £349 for the E60 multi-region - still looking on the JVC as I cant find anyone who specifically mentions its multi-region.
    RickB
  2. Easy2BCheesy
    Easy2BCheesy
    May 8, 2003
    343
    16
    Personally I'd wait for reviews on the DR-M1 before making any decision, or else go with the established E60.
    I was very keen on replacing my DVDR890 with a DR-M1 as its built-in component output/progressive scan would be very handy for my plasma screen.
    However, the manual for the DR-M1 is online, and it *seems* that RGB SCART input is not an option, which for me makes the E60 the obvious choice from a quality recording perspective.
    No RGB SCART recording? No way I'm parting with my money!
  3. RickB
    RickB
    Easy2BCheesy,
    Do you have a link to the online manual for the DR-M1 ? I checked JVC's website and sadly failed miserably to find it !!
    RickB
  4. RickB
    RickB
