Which recorder for dual layer discs??
Discussion in 'Blu-ray & DVD Players & Recorders' started by andymc, Nov 24, 2004.
  1. andymc
    andymc
    Sep 18, 2003
    266
    Bedford
    +15
    Wondering if anyone knows which recorders are available that will do dual layer discs and what software do I need to upgrade my computer or does it require a new DVD drive?
    Any help would be appreciated
    Andy Cuthbert
  2. Bosco
    Bosco
    You need a new drive and they are only available for a PC not standalone. Pioneer and NEC make some of the best dual layered multi-format drives out there, have a look on www.svp.co.uk for prices. Regarding software I believe the latest version of nero does it. If you get an OEM drive you will need to purchase the software seperatly.
  3. waz2004
    waz2004
    Sep 14, 2004
    296
    +6
    i don't think there is a standalone dvd recorder that can record onto dual layer dvd.
    the only option you have is to get a dvd writer for the PC. There are several external and internal dvd writers that write onto dual layer. They start from £50ish.
    At present there are several mags reviewing DVD writers.
    Regarding software it should be supplied with the DVD drive. Also check if it is supplied with editing software such as nero6.
    www.dabs.co.uk
    www.novatech.co.uk
    www.amazons.co.uk
    google
  4. SDHoward
    SDHoward
    Nov 1, 2004
    250
    also www.scan.co.uk
    if you also want to cover all formats including RAM then LG is a good drive
