which receiver?
Discussion in 'AV Receivers & Amplifiers' started by avmunster, Aug 12, 2002.
  1. avmunster
    avmunster
    Aug 12, 2002
    198
    Hartlepool
    +5
    I just bought the eltax evolution speaker set and was wondering which reveiver to get. I got around 400 quid to spend and was looking at the yamaha 630 or marantz 5200???
    I just keep thinking about the denon 3802 for 599.00!!!
    what u guys think?
  2. paiger
    paiger
    You should be able to get the Marantz 6200 for £400. I think the spec is a fair bit better than the 5200.
    S
