Which Rear speaker cable?
Discussion in 'Home Cinema Speakers' started by silentbob, Jul 12, 2003.
  1. silentbob
    silentbob
    Dec 21, 2002
    122
    York
    +8
    Just ordered some Aegis Evo Compact Speakers for my rear effects. And I really need to upgrade my Boyes special 3 core electrical cable I have currently. :blush:
    Can anyone please recommend speaker cable for the job, ideally no more than £4-5 per metre? They are to be driven either by a Marantz SR 5300 or a Denon 2802.
    Any help would be much appreciated.
  2. nathan_silly
    nathan_silly
    I wouldn't even spend more than £2 for rear cable, let alone upto £5m/m .. try some 16 gauge from Dixons (think 15 or 20M for £17)
  3. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,080
    notts.
    +63
    Qed micro.
    Good quality £1 metre.Easy to hide.
    Gonzo.
  4. Seeker
    Seeker
    Gale Hyper-latz 250, £2.50 per metre. Very open, detailed and easy to hide.
  5. davidhunter
    davidhunter
    Feb 19, 2003
    209
    Glasgow Scotland
    +11
    IXOS 6003 got it off a guy on Ebay for £1.25 / m normally around 3 or 4 a metre.
    Sounds good but see my other questions about positioning.
    Davy
  6. silentbob
    silentbob
    Dec 21, 2002
    122
    York
    +8
    Gonzo, where'd you find the QED for £1 a metre? Cheapest I can find is £1.50.
  7. Godfather
    Godfather
    Feb 12, 2001
    2,345
    63
    Edinburgh
    +225
    I use unbranded 79-strand cables for the rear speakers.
  8. Grimley
    Grimley
    I use 1.0mm lighting cable for wiring up my rear speakers, picked up that idea from a late 80's Hi-Fi mag.
  9. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,080
    notts.
    +63
    Hi Bob
    I got it from hifi junkies with other stuff i ordered.
    Gonzo.
  10. silentbob
    silentbob
    Dec 21, 2002
    122
    York
    +8
    Bum, never mind eh :)
    Think I'll go with some 79 strand I found on lektropaks webby.
  11. dejongj
    dejongj
    I use Chord Carnival with my Aegis Compacts as rears. £2.50 per meter with the advantage that it has a white jacket around the cable....
  12. Dean
    Dean
    Jun 20, 2003
    2,885
    London
    +262
    I use Cable Talk 3.1 for centre and surrounds, QED XT300 for fronts.
