which really small budget speakers(£100)
Discussion in 'Home Cinema Speakers' started by mt50, Jan 23, 2005.
  1. mt50
    mt50
    Oct 24, 2002
    1,431
    stoke-on-trent
    +84
    hi, i'm looking at upgradeing my hifi in 4 steps-
    1) new speakers+cables
    2) new amp
    3)new cd player+dab radio
    4) new interconnects.
    at the moment i've got a sony all in one job CMT-CP11, and i'm wanting to know if i can add so better speakers to it now, or wait until i can afford an new amp aswell?
    in the manual it says-
    DIN power output(rated) 30+30W
    (6 ohms at 1 KHz, DIN)
    continuous RMS power output(reference) 35+35W
    (6ohms at 1KHz,10% THD)
    music power output(reference) 85+85W
    so does that mean i can use other speakers with out damaging them?
    if it does what are good speakers for around £100-£130?
    i will be useing them in my bedroom which is aprox 15-20x15-20 foot.
    i only really listen to hip hop/rap so i need good speakers for that kind of music.
    i've had a quick look on richer sounds and picked out a couple of pairs-
    floorstanding-
    http://ws4.richersounds.com/showproduct.php?cda=showproduct&pid=MISS-M73I-BCH
    stand mount-
    http://ws4.richersounds.com/showproduct.php?cda=showproduct&pid=MISS-M71I-BCH
    http://ws4.richersounds.com/showproduct.php?cda=showproduct&pid=MORD-902-MAP
    now i like the mission m71 as they are the cheapest, but the MS 902 look very nice, and i would save up the extra if they are worth it.
    also as anyone got any recomendations for a good budget amp(£200 ish)
    fo when i can afford one?
    was looking at the cambridge audio 540 or 640.
    but i also want a surrond sound system so would it be better to go with a amp like -
    http://ws4.richersounds.com/showproduct.php?cda=showproduct&pid=CAMB-AZUR540R-SIL
    any advice would be great.
    thanks
