Which Radeon Card
Discussion in 'Desktop & Laptop Computers Forum' started by zypheruk2004, Jan 8, 2004.
  1. zypheruk2004
    zypheruk2004
    Hi folks im looking to put a radeon card in myhtpc system and im looking for advice on which card to buy.
    I need perect dvd playback, and play some games, i also need to b able to controll the card via my pda.
    Is it worth buying the AIW cards.
    Or advice on differnt cards is welcome.
    Many Thanks
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    All Radeon 9xxx cards produce the same DVD playback quality. For gaming you'll probably need a 'Pro' variant, whether a 9600 or a 9800 depends on the type of games you play .. be aware that Pro versions have fans which can be noisy for HCPCs.
    Don't know what you mean by driving the card via a PDA .. but then I don't have a PDA or remote operation beyond a simple hand-remote.
