Hi All,
I'm into looking for a replacement GFX card to replace my current GF4 MX440 GFX Card.
After looking around i guess anything from the ATI Radeon series 9500 and up is very worthy for use in an HTPC. It seems that the Sapphire Radeon range look good.
My budget is around £100, so i was looking at a Sapphire Radeon 9600, but i'm confused by the different specs. SE, XT, Pro and any others ??
I will be using a Pioneer slot loading DVD Rom drive, and PowerDVD v5 in my HTPC, just need a suitable GFX card.
What do you lot recommend ??
Cosmic023
Cosmic023
