Which Radeon can do this for me?
Discussion in 'Desktop & Laptop Computers Forum' started by Desmo, Mar 19, 2003.
  1. Desmo
    Desmo
    Jan 4, 2001
    13,565
    Braintree, Essex.
    +4,935
    OK, my current setup uses a 7200 to feed a 32" Widescreen TV via S-VHS.
    I've recently aquired an 18.1" LCD monitor that will be used alongside the TV.
    My problem is the TV is limited to 800 x 600 and I want the monitor to run at 1280 x 1024 but the 7200 can't run a different res on different devices.
    I've seen the newer versions now use 1024 x 768 for TV-out which is fine.
    All I really need to know is can any of the newer Radeon's run these two resolutions on different devices at the same time?
  2. MonkeyDonkey
    MonkeyDonkey
    May 9, 2002
    401
    UK
    The 7500 and onwards can run two displays (one being tv out if you want) at different resolutions.
  3. Desmo
    Desmo
    Jan 4, 2001
    13,565
    Braintree, Essex.
    +4,935
    Looks like you're right mate. Seen something on their webby called Hydravision. Looks like it does what I'm after. Just need to find the best card for me now, don't really want to be spending mega bucks on it.
