Which rack for my plasma...
Discussion in 'Plasma TVs' started by stevedster, Sep 18, 2005.
  1. stevedster
    stevedster
    Jan 13, 2005
    1,128
    48
    Birkenhead
    +41
  2. Badger0-0
    Badger0-0
    May 30, 2005
    20,583
    Spaghetti Junction (really)
    +1,921
    Both nice.
    I would have recomended one from Index. £100 and very nice.
    But they've closed.
    The only thing I would say about the Argos one is that the middle shelf seems a bit low. Depends on what kit you have, I guess.
  3. stevedster
    stevedster
    Jan 13, 2005
    1,128
    48
    Birkenhead
    +41
    well the kit i will be having is prob gonna be,
    dvd recorder, dvd player, xbo 360 and media box, plus also for the future a blu ray dvd player.
  4. Badger0-0
    Badger0-0
    May 30, 2005
    20,583
    +1,921
    Probably ok then :smashin:
    On mine, I have a centre speaker on the bottom shelf.
    With it being in the centre, it leaves no room for anything else :(
    Putting the speaker on one side would look stupid, IMO.
    So, on the top shelf, I have the Yamaha 557 amp and the DVD with the Sky box on top.
    Not great, aesthetically(sp) :(
    I was thinking that if you have a biggish centre speaker, you might be a bit stuffed.
