Which Quad LNB?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Les E, Nov 16, 2004.
  1. Les E
    Les E
    Oct 5, 2004
    963
    St. Helens
    +18
    I am looking at a Quad LNB for Sky Digital and I am wondering if there's any difference between makes.
    I've been looking at a Raven, Cambridge and Skyware LNB. Does anyone have any opinions on the above?
  2. gbmitie
    gbmitie
    Apr 25, 2001
    1,141
    49
    republic of ireland now
    +62
    They are all much of a muchness ie very little difference apart from price. What you have to watch is the fitment. If u have a sky dish then its best to go for an lnb that is compatible with dish, makes fitting easier. if it is now a sky dish then they are usually sold with a 40mm collar or with adaptors.
    Sky has a very strong signal in uk and eire so u dont need a supder duper sensitive lnb.
    Save urself some money and buy from ebay.
    gbmitie
  3. Les E
    Les E
    Oct 5, 2004
    963
    St. Helens
    +18
    Thanks for your info and I have already bought one from ebay prior to your post...uncanny!!!
    :laugh:
    Cheers!
