Which qed cable?
Discussion in 'Arcam Owners' Forum' started by lappy4711, Jan 8, 2005.
Tags:
  1. lappy4711
    lappy4711
    Ok, so which qed cable should I get if I want to connect a rgb scart coomponent such as a cable box or a game console to the AVR300 and then convert that signal to component to send to my projector?
    Here is the "sqart" range:
    http://www.qed.co.uk/cables/sqart/sqpl.html
    Seems stupid to buy a rgb->component converter if that functionality is built into the AVR300.
    Thankful for any help
    Lars
